After removing and later reinstalling the front drivers seat, the ABS began to light up ....and always stays lit. What's up?
Have you removing battery before doing any works on your seats if not that causing issues.. Or could becoming from a bad contacts or loose wires under the seats
Your only solution is to go at workshop for erasing error message as you can't work on it as it is protected from misuse or bad results (accidental firing)
1) tech 2 could do the job also
2) Bosch diagnosis wallet aswell
Hope it helps you...
That's a new one on me,you removed the seat , re install it and the ABS light comes on!
As above, a good diagnostic tool will pin point Aera of concern ( front or rear , left or right )
But without knowing where the fault lies it's all,a guessing game .
