Hi,
I have just replaced the front pads and discs on our SAAB 93-2002 convertible and the brake pedal judders (ABS) at very low speeds as if the ABS is kicking in.
Any ideas ?
Only thing I can think of . is .are the abs sensors clean and are they seated propley?. Are the discs clean ( did you spray them with brake cleaner before installing ? If there are anti rattle springs were they replaced or are they seated propley ?. Just a couple of thaught from my brain cell .
Discussion Starter #4
Thank you all for your responses, to update you it was the thread / nut that holds the off side ABS sensor - it had sheared off !!! - All now replaced and working fine.
Enjoy the Festivities!!!
