Hi all. My problem is that both my ABS light and brake warning light come up every so often for about 5 seconds and then go out. I think it is unlikely to be a sensor, as this also happens if I pump the brake pedal 4-5 times when stationary. Could this be caused by old fluid? Any idea what else could it be? My dealer was unable to pull any codes.
Harry
1992 CS Carlsson auto
there may be a clue here
My experience is ..a sensor going out and the abs light comes on and you have to re-set it by turnning ignition off and on
However I was suffering a rather nasty leak and when the fluid got too low the lights would come on as before when it detected low fluid but would go off without having to re-set
I would therefore suspect the fluid level sensor
as the likely dirty contact..
(do not know where it is though...)
Small update: With the key at the on position (so that it is quiet), pumping the brakes 4-5 times hard turns the lights on and I can hear something running until the lights go out, I assume this is the pump.
What can cause the pressure to drop that much? Is it a bad accumulator?
Harry
