Cabin Heater only blows cold air. If I put it on Re-circulate, ECON, fan on 3 bars, 88 F. degrees, it will blow maybe 60 F. degree air, when ambient is 40 F. degrees. Still too cold for the wife. I understand that there are 2 likely culprits: heater (coolant) mixing valve and flapper (air mixing) valve. The latter could be a problem with either the servo control motor, or the control arm. Question is: where are they located? How to change them (like what has to be removed to access them)? Are they expensive? Car is a (US) LHD convertible 2002. Diagrams? Thanks!
