I'm trying to solve a bit of a puzzle with my A/C. It wasn't working well today and I recall reading the thing about blowing off the valve on the compressor and thought that attention to avoid that would be good.
When I first got the car, I took it to TrentSaab who commented that it was a little odd that the radiator fan came on with the compressor. The problem that this causes for me is that it's two loads at the same time and really slugs the engine and can stall it when the A/C compressor is working hard.
I lived with it but then when the head gasket was fixed, somewhere along the line, the behaviour was changed and the fan no longer came on. At first I thought "this is good, no more slugged engine" but of course the upshot is that there's no airflow at low speed to cool the A/C radiator either and hence poor A/C.
This evening I had a bit of a delve around and found a black wire which was tucked neatly back into the long sleeving which the garage must have done when they wondered what this wire was for. I traced it up to what appears to be a relay under the aquarium and indeed, if I wire this in parallel with one of the engine radiator coolant switch terminals, I'm back to the fan coming on with the compressor.
I'd really like to nail this one properly though because that does seem wrong and if I turn the ignition on and press the frosty button on the dash, the behaviour is that the magnetic clutch on the compressor engages and the fan comes on. Not exactly what you want when starting the engine.
I also found a thin blue wire exiting the loom with a bare end at the same exit where the wires to the radiator switch also exit.
It gets better, under the aquarium, the low pressure switch on the dryer has four wires, the green ones are cut off right at the connector and hence go nowhere.
I'd like to know, when is the fan supposed to come on in relation to the compressor clutch on manual A/C? Answers of "intermittently" won't help here, I need specifics, it seems like there ought to be a short delay or based on some other sensor so that both aren't operating at the same time.
Can anyone provide a schematic because Haynes has nothing on this.
David.
David.
