Hi folks.
have been having problems with my heater in my 9000 annivers 97. the problem is that the temp needle on the dash seems to be very low down the scale and looks like it is running cold, also i can only get hot air if i put the heater setting to the HI setting. I also recently changed the thermostat and coolant and it was running good with the temp needle at exactly half way up the guage and hot air coming out at 70 degrees setting. Could it be the sensor on the engine and if it is how much would it cost and how easy is it to change and wher is it any advise appreciated.
kimosaabi
kimosaabi
