Just put an engine into my TTID, put the ignition on and can’t hear the fuel pump going. Traction control messages on the dash and no cranking. Just a click from what sounds like a relay in the glove box the first time the key is turned. Fault codes remain in the system and can’t clear. Few attached that stand out. Anyone can point into any direction of what to check next? Everything seems plugged in and in the correct place. Unless something was done wrong 😬
It cranked just don’t run well before replacement.
53270
53271
53272
53273
53274
53275
Saab 9-5 2.3T Aero Auto, Nocturnal Blue
Hi there,
Have you gotten the saab to start yet?
One major things with the 9-3 is the battery
Is the one you are using a fresh one or a good condition one?
