I have a creaky squeeky plasticy rattle from the area around the gear stick. Sounds like it could be the plastic surround. Anyone come across this before and what the fix is. Only started a couple of thousand miles ago.
93 vert 2010. 1.9 tid vector sport TX 54000 miles.
As you say, more than likely a plastic on plastic nuisance. Normal car issue. Take as much as you want/dare apart. Wipe down with a vinyl/rubber/dash/trim cleaner/conditioner/restorer. Especially the mating/joining surfaces. This has many benefits. Cleans, protects, rejuvenates, shows you how things work & fit together. PLUS, it makes them look prettier :))
Second. I vaguely remember that the shifter bushings wear/become sloppy. And again vaguely, this is manual only, & changing gears is an issue.
