I am attempting to check the timing on my '91 9000S 2.0 manual (normal spark plugs!). The Haynes manual states that the marks are visible through the transmission housing timing aperture. Unlike every other car I have worked on, I cannot find where this is! Can anyone advise please?
assuming you don,t have d.i look directly below distributer,on g/box housing is a slot with a notch in the middle . jack up car and turn drivers wheel until 'o' mark on flywheel is lined up with notch. if 'v' marks on camshafts aligne with marks on bearing caps the timing is ok.hope this is of help..
