I had read stories of huge cost to replace the timing chain, so having changed one recently on a 900T 16V whilst the head was off I decided that as my 9K had done 200K I would replace the chain in situ to prove a point that it can be done in just 2 hours as long as the tensioner and guides are not worn out. The chain I bought came with a split link so it was just a case of being very carefull and just feeding it on a small amount at a time. unless you are a fairly skilled engine man I would not reccomend you try it but I can now confirm that it can be done. I thought my engine sounded okay before I did it but now its done it sounds so smooth and quite and no noise on cold start up and it does seem to have a bit more get up and go. If anyone would like more info and the timing chain make and part No I will gladly give a more in depth step by step.
I also have a very simple method to uprate your boost without expence or problems.
