Would appreciate any pointers as to why my 9000 lpt my96 has recently become next to impossible to start after being left for more than 3 days. Engine turns over normally but does not fire up. So far a squirt of easy start into the throttle housing has coaxed it into life cylinder by cylinder. Once running on all 4, no problem, pulls well and ticks over fine. Starting it the next morning is no problem but leave it for more than 3 days and the nightmare begins again . So far I have tried the following: new plugs and air filter, new ignition cartridge, cleaning the crank sensor, new battery, WD 40 over all the electrical connectors I can see. Saab have put it on their test equipment and no reported fault codes, compression is between 160 and 175 on all cylinders, no odd noises from the engine, no air leaks and dealer confirmed runs as it should on road test. The car has done 156K miles and all items I have changed have been done one at a time to try to identify the problem but so far nothing. Dealer says if the fuel has drained back into the tank it may take a few seconds to start but it would then start on all cylinders and if fuel pump was faulty it would affect performance more than cold starting. Sorry about all the detail but I wanted to cover everything as it does not seem to be related to the normal culprit of the ignition cartridge.
