Originally posted by Adrian:
[qb]
However, I'm not sure if a 1993 lpt is trionic or not[/qb]
I thought all 9000 Turbos from '93 on were Trionic, but there are both Trionic and LH modules listed for the B202 turbo engines in '93, so I don't know.
Good point, Mark. The AMM/MAP will tell.
Anyway, in the absence of fault codes, we'll just have to investigate the symptoms. Stalling while coming to a halt is often a symptom of a knackered turbo bypass valve (dump valve). However, I would have thought it should restart immediately if this were the problem.
How do the plugs look? If they are very dark, perhaps there's a fault with the AMM (assuming you have one) or lambda sensor, causing rich running. I would think it would need to be very rich to cause it not to start.
Perhaps a DI cassette fault, although I'd expect to see other problems under load before you get idling/starting problems.
