9-5 manual 5th gear selection
1 reading
4K views 4 replies 2 participants last post by  wootang
#1 ·
MY99 9-5 2.0 manual
My gear shift transverse movement is excessive to the right making changing up 4th to 5th something of an art The lever seems to overshoot the placement where you push forward for 5th. Has something broken off? , a stop perhaps, or is there something more sinister inside the gearbox? Is there any adjustment available, if so how do you reach it?. Any help would be appreciated.
#5 ·
The problem is solved !! Lifted the gear lever gaiter to look for the alignment hole and found the "mounting frame" was missing !!!! I think this might account for the excess right hand movement and the fact that reverse can be selected without raising the finger lift under the gear knob. All there is under there is a white plastic cup with spring loaded device in bottom, the reverse gear finger lift mech is still on the gear lever shaft but not connected to anything.
Has anyone out there got a spare they would like to sell me? or can recommend a breakers?
