61 - 80 of 101 Posts
Only had mine for about 5 days - is a 98 2.0 LPT manual.
It stank of oil in the cabin when I came to a stop. Quick investigation and a squdigy breather pipe seemed to be the source. Took it to a specialist who removed the breather pipe to show a big hole! Smell now gone.
It wobbles a bit around 65-70mph, though I believe this is the wheel balancing.
Most worrying is the reverse gear, which is sometimes (1 in 5) difficult to engage. Sounds like it needs the reverse gear kit to sort. (Not cheap )
Oh, and the obligitory mixing pixels on the SID display and to a lesser extent on the climate display.
Update on mine - the wobble at 60mph ish was the wheel balancing on the rear wheels. Cost £10 to fix.
Reverse gear is behaving itself too - gets sticky now and again, but it doesn't feel like anywhere in need of attention.
Enjoying the car now - it's perfect for my 36 mile commute to work, comfortable, swift and safe
Fellas
As the need for an estate looms ever closer, the time might be ripe to trade in my 9-3 for a 9-5 estate. Have seen one advertised, at a good price but have a query ref engine specs. Is advertised as a 2.0t SE, which I would assume to be 150/154bhp, the same as my 9-3. Ad claims it has 185bhp; can this be true? It's a 99 T plate SE manual. Plenty of gen on here for me to stick in my back pocket, should I go to view this or any others. TIA.
And I know - if it seems to good/cheap to be true, it probably is!
Here is a list of the problems I had with my MY01 Aero estate which I had for 4 ½ years from new up to 91,000 miles. Overall I was very happy with the car, particularly the performance, comfort and build quality of the bodywork which still looks immaculate. The mechanics don’t seem quite as good, but Saab has handled the warranty well. Most of the problems are known and reported in other messages. Apologies in advance for the essay but sometimes you just have to get it down!
The SID failed early on (first year) and was replaced and has been fine since. Other early failures included the electric radiator fan fuse, which caused it to overheat in traffic, and a wiper motor that packed up. I’ve always wondered since whether the overheating caused any permanent engine damage.
I had problems with the gearbox from day 1 with moves into reverse baulking right from new. Second gear failed completely at about 30,000 miles and when fixed under warranty was found to be a cracked 2nd gear wheel. The gearbox gradually deteriorated and eventually proved impossible to get into reverse unless the engine was off and gear changes became increasingly notchy. This led to a major rebuild under warranty by the dealer, and was a ‘known problem’ with Saab having released a modification kit. I was annoyed that I’d had to be quite insistent with the dealer before this problem was looked at and then even more annoyed when they admitted that the kit was available and could be done under warranty. Even after the modification the car was still occasionally difficult to get into reverse and could jam when trying to move into lock position with the gearlever halfway, requiring the car to be rocked forward and backwards to move the gearbox enough to locate the lever properly. I presume this is the same problem with the synchromesh on reverse as discussed elsewhere on Saabscene.
The DI pack failed causing an engine shutdown whilst on one trip requiring an RAC pick up and drop at the dealer. It was then found that the exhaust cat was also damaged by the neat fuel that had been pumped down the exhaust so this had to be changed. Luckily this was all done under warranty. Some time later the DI pack failed again, this time outside the original warranty but covered by warranty on new parts so replaced FOC.
A new thermostat was needed outside warranty at just over 3 years and 54,000 and a new airflow mass sensor was needed at 62,000.
At the 78,000 mile routine service the dealer told me of a modification that Saab was recommending involving a new breather pipe and valve kit. I held off having the work done and when I called a few months later to book the car in for the work found that the modification had been withdrawn, it was causing more problems than it was solving! Instead of the modification Saab increased the engine warranty to 8 years providing the car had a full service history.
A problem with loss of power was traced to a throttle body seal at 86,000. Shortly after this the car began consuming oil and mayonnaise appeared on the oil dipstick and the 90,000 service confirmed a head gasket problem but Saab agreed to do necessary work under warranty. Further problems were highlighted with the rear suspension bushes and brakes, but these were only really to be expected in a car that is getting on for 100,000 miles.
Other work done included replacing drivers door window when the car was broken into on a visit to London and the repair of a dent in the bonnet and door which appeared after being parked on a public road. Dent Devils did the repair which was first class.
I’ve just replaced the Aero with a new 3.0 TiD so I hope this one proves to be a bit more reliable and I promise future posts will be shorter!
First post, and a happy owner. Had a 9-5 2.3SE Estate Auto since Apr 2001 (ex-demo car 7K miles), now on 93K miles and the the list of faults are:-
SID screen failure (78K miles) - replaced under extended third party warranty
DI pack (90K miles) - replaced under third party warranty
Heated front seats, matrix came adrift causing burning smell - pulled fuse, don't really need them
Thats it! One of the best cars I've ever owned and much cheaper to run then my previous Audi A8.
Mr Perceptive
Well since we're getting it down.
I have owned my 95 2.0 lpt for a few months now and the worries for me are a grumbly PAS rack/pump light left lock accasionally.
It has been sticky into reverse once which was probably heavy handedness.
The potential muck in the sump from it doing short runs then nothing for a while and the last oil was in it for well over 12k. WMSS will be cleaning it out on 66k service.
The AC is being regassed today, prior owner ran it on ECON a lot me thinks.
The driver seat needed lots of lubricating and loving to stop squeaking and rattling & are not a patch on the 9000 CSE seats.
There is an (sounds common) audible rattle in the passenger door whith the window over 1/3 down.
The gear stick vibates a bit with welly, similar to the 9000 I had which never missed a beat till I hit something in it.
The SID II works ok but alas the AC display is shot to bits.
All considered she has got better and better the more I have driven her and for a 1997 registered 95 I am pleased with her.
In comparison to the recently deceased manufacturer produced car I owned prior, she is an absolute joy. Dare I tempt providence.
I look forward to boring WMSS senseless with her this afternoon.
Thanks for the extnsive advice here it was agreat help when purchasing a Saab 95.
12 months now in my 1999 2.3 auto lpt se saloon and apart from the fuel consumption (average 23mpg) everyting seems fine......watch this space for expensive explosion!
Only probs have been a blown SID display ( fixed before purchase) and an A/C re-gas. Buy one and enjoy
My 9-5 3.0 TiD estate continues to be a great car, the best I have owned to date, few problems and those were mainly engine software related in the early days, now 62k on the clock, and 42mpg.
The original plan was to keep it for 60k and change but been so pleased with it I recently decided to keep it for another couple of years and purchased an extended warranty from Warranty Wise - just in case.
The Saab dealers I have used have always been very obliging, helpful and friendly.
My only moan about the car is the number of fog lights it eats - 6 in 2.5years!!! and they are not cheap to replace, but apart from that minor niggle would recommend the car to anyone
Hello All...
Its been some time since I last posted on this site (and its nice to be back).
I am now looking for a 9-5 Aero probably with a budget between £12-£15k. I recall from some previous posting that the spec of the 9-5 Aero changed and some updates were made around the 2001/2 time period?
Can any one point me in the right direction.
I'm trying to find our when these "upgrades" were applied and what they were.
EVO
Upgrade was really only for the latter part of the 2002 model year. All they did was make the "Aero Lux Pack" standard.
Aero Lux Pack had (from memory):
AS3 9 speaker Harmon Kardon audio
Rain Sensing wipers
Electric front seats (driver's with memory
Auto dimming rear view mirror
Park assist
heated front and rear seats
Xenon lights
Later years started deleting these standard items as well as a few more (door pillar nets, emergency triangle, lashing bits in wagon etc) and added others to the options list (folding door mirrors, satnav etc).
With your budget you could get a 2 year old car, but that age is when the standard stuff was being "decontented" so check the options!!
I have just one. When filling up at the pump, be certain you click your gas cap THREE CLICKS tight. Otherwise that "donate money to the dealerhip for nothing" light will come on and it will have to be turned off at the dealerjip!
Besides that, the 9-5 is the greatest car I have had the pleasure to drive. And I have owned 22 cars in my life. A 1982 Lancia Zagato is second. And a CLOSE second.
Hi - I've just found this forum while researching buying an 02 9-5 HOT. I'm now getting cold feet! 50k services costing over £1000, engine oil sludge, turbo failure. Are these cars a good buy or is the consensus to avoid them? I can't afford to make a costly mistake!
I've had several Saabs before (starting with my first car a 96 v4) and thought they were all great.
Thanks in anticiption.
I'm close to never visiting this place again - and any other Saab forum, as they're just full of people complaining about the unreliability of their Saabs. It's scary! We've only owned ours 6 weeks; thank God it's got almost 2 yrs warranty left, if the posts are anything to go by.
Sludge and turbo issues are less of a problem on the Aero HOT. It should have had synthetic oil from new. It has a different turbo from the other models. My 02 Aero has had a new head gasket under warranty and had the 60,000 "big" service at a main dealer for £600. If I wasn't close to that dealer I would look at cheaper specialist servicing. Make sure you find a late 2002. They came with the Aero lux pack - 9 speaker radio, rain sensing wipers, xenon headlights, electric seats + driver memory, heated sets etc etc.
