cutting out whilst driving happens each few hundred meters or 1km. Starts well again.The dutch AA could not see any fault messages on his advanced equipment. I searched in this forum and GM forums for the same issues.
I try to get an idea where to start first
What I found:
1.injektor leaking back so pump cannot keep up the pressure... drop of pressure .......cutting out
2.connector injektor 3 wiring
3 wiring problem between injektors and ecu
4.pressure fuelpump in the fueltank
5.egr stays open so it gets to much gas
6.connector fuel rail
7.drop out relais fuelpump
8.crank sensor (start with that tomorrow)
Discussion Starter · #2 ·
I have been working on the car several weekends with no result yet.
I had diagnostic check at dealer. Bad fuel pump in the tank was the problem said the garage. New fuel pump in........still the same. When I lift the car to the left side so it hangs to the right it runs fine and I could keep up 2800 rpm for about 5 minutes or more if I wanted.When the car is on four wheels it cuts out after a short while.????????
I also checked wiring between ecu and fuse box .New filter in .No dirt found in the lines,filled up the tank.
