Hi
looking for advice, couldn't find earlier similar issues on this site.
Found a small diesel leak under my 2011 9-3 TTID. It appears the black rubber housing has shifted or the cylinder in it has shifted. Either way it is loose in the rubber housing.
Pictures below,
https://drive.google.com/open?id=1zJUadOlIPM2HFXD6ZaXaC9_lg2qg9iY_
Any ideas?
Could you help me with the part numbers. Don't seem to find anything on TTID.
The parts are in the EPC (Tech2 section Saabcentral)
You will need to remove the strap which is holding the filter assembly and check where the leak is coming from.
Also highly likely the Insignia 2.0cdti has the same parts
as they used the same engine but do your homework.
Discussion Starter #3
Hi
I think I located the part, 13139977 park heater fuel pump.
Also added a video to my link for better understanding. Couldn't make sense see where the leak was coming from, either way it seems messed up in the housing.
