Overview, 4D
• Entertainment head unit, EHU (353)
• Audio System Amplifier, front speakers, AMP1 (354F)
• Audio System Amplifier, rear speakers, AMP2 (354R)
• Control panel, infotainment, ICM (736)
• SID (541)
• Speakers, dashboard, left/right (266 FL/FR)
• Speakers, rear, left/right (266 RL/RR)
• Speaker, dashboard, centre (266 FC)
• Speakers, front door, left/right (266 LH/RH)
• Speakers, woofer, rear, left/right (266 RLW/RRW)
• Antenna (625)
• Antenna amplifier, radio (624)
• Antenna filter (644)
• Steering wheel controls (633)
• Column Integration Module, CIM (703)
• Connection, AUX (771)
Overview, 5D
• SID (541)
• Speakers, woofer, rear (266 RCW)
• Antenna (625 RL/RR)
• Antenna amplifier, radio (624 RL/RR)
Overview, CV
• SID (541)
• Radio antenna (364)
• Bypass unit, antenna amplifier (624a)
• Antenna amplifier, radio (624b) (integrated into antenna base)
Amplifiers and speakers, 4D
The main entertainment unit has an integrated amplifier that drives the speakers of the Premium 70 sound system. The Premium 70 sound system has two speakers on the outer edges of the dashboard, 3.5” and two on the outer edges of the parcel shelf, 4”.
The Premium 150 sound system has two additional speakers in the front doors, 6.5” and a centre speaker in the dashboard, 4”. There is also another amplifier mounted under the left-hand seat.
With the Prestige 300 sound system, there are four additional speakers located on the parcel shelf, two tweeters and two bass 6”x9”, and two more tweeters on the dashboard. To drive the two bass speakers, an amplifier is fitted in the boot on the left-hand side.
All speaker cables are twisted pairs. This makes them less sensitive to the induction of disturbances from other wires.
Amplifiers and speakers, 5D
The central entertainment unit has an integrated amplifier that drives the speakers of the Premium 70 sound system. The Premium 70 sound system has two speakers on the outer edges of the dashboard, 3.5” and two on the outer edges of the luggage compartment, 4”.
For the Prestige 300 sound system, there are an additional two tweeters in the luggage compartment and one bass speaker under the luggage compartment floor. There are another two tweeters in the instrument panel. An amplifier is mounted on the right-hand side of the luggage compartment to drive the bass speaker.
Amplifiers and speakers, CV
An amplifier for the speakers in the Premium 70 audio system is integrated into the EHU. The Premium 70 audio system includes two speakers on the outer edges of the dashboard 3.5” and speakers in the right-hand and left-hand rear side trim 4”.
The Premium 150 audio system includes speakers in the doors 6.5” and a centre dashboard speaker 4”. An amplifier for these speakers is fitted under the left-hand section of the rear seat.
The Prestige 300 audio system includes two tweeters in the rear side trim and two woofers behind the back seat backrest 6”x9”. Two additional tweeters are located in the dashboard. An amplifier for the woofers is fitted on the left-hand side of the luggage compartment.
Single CD
6CD Changer
ICM1
ICM2
ICM3
If replacing the stereo, the ICM MUST stay connected, but the front easily comes off, so it can be hidden behind the dash.
The EHU is located above the CD player behind the heater controls.
The EHU uses a standard Fakra Quadlock. If you want to remove this, you will lose all the car sound indicators, seatbelt warnings, and parking sensors.
You will need a fake quadlock to iso for power and speaker connection and a phony to iso/din for FM/am aerial
But if you use a parrot adaptor, you can fit an aftermarket stereo but keep the sounds by using a centre speaker. You must move the optical cables from the loom to the adapter. Also, if the CD player or amp is removed, you will need to bypass it using an optical loopback.
Parrot kit
Loopback adapter
or
• SID (541)
• Antenna (625)
Overview, 5D
• SID (541)
Overview, CV
• SID (541)
Single CD
6CD Changer
ICM1
ICM2
ICM3
Parrot kit
Loopback adapter
or
