1 - 20 of 54 Posts
(MADE AS A STICKY FOR THE HOT WEATHER UNTIL THIS CAN BE MODIFIED/SORTED AND SIFTED THROUGH)
Today of all days on a long journey, it was time to put the roof and chill the car as the sun was to strong. BUT the cabin air refused to chill....did work, and just. Stopped like that. IT MAY be linked to having the car serviced ( just a thought ) any ideas on what to check. Air is blowing but it's not chilled.
Re: 09 9-3 stopped blowing chilled air
AC turns off when hood lowered - a green light on 'AC Off' button indicates AC Off. You can turn it on manually bt pressing same button - light goes out.
Discussion Starter #3
Did that mgb, it's not playing fair, just moving warm air had to crank all windows down as passengers in back were complaining of heat.
Premium Member
I suspect you are low on gas, either its just low as they do need topping up from time to time, or you have a leak in the system the most common cause is a stone has punctured the aircon condenser
it is also worth while checking the clutch engages on the compressor
don't just have the system refilled...........if you have leak the gas will just escape so false economy £ wise
the best option £50ish is to
evacuate any remaining gas this will also remove the pag oil
vacuum of the system 20mins min this will remove any moisture from the system (death to aircon)
after vacuuming the system the machine will do a leak test
refill with the correct quantity of gas and oil along with a dye which will pin point any leaks under uv light
Discussion Starter #5 (Edited)
Thanks for the Kez pretty comprehensive list that. Had a quick look this morning (I dont use the car for work) and I noticed that the LED on the "auto" button is not working. but the button does work as the fans change pitch when I cycle it. Nothing obvious under the bonnet, I did see a mention of holding the auto button, and aircon off switch together (dont know if the relates to my model) however it didnt do anything. I suppose next stop is a garage. Cant manage without that aircon (well I can but its not good as we found out yesterday)I cant sense a change in engine note when cycling the aircon off button. (but then I cant honestly say I did notice it.) So I dont think the clutch is engaging the compressor.
Premium Member
if it is low or no gas the a/c wont turn on, when was last time you used was it ice cold or have you noticed it getting warmer air over a while.
ring round a few aircon specialists get a few prices first. tell them your after a recovery and recharge with vacuum
Discussion Starter #7
I've had the car about 18 months (ish) and I have never been happy about the cold air from the day I
Picked it up compared to my 2 previous vehicles. Since Feb I don't think it has done 1000 miles as I have a contract where I walk into work. I have been put in touch with a guy who specialises in Aircon, apparently he will charge 50 quid for a pressure check flush and re gas, and will come to me. Ill let you know how I go on.
Discussion Starter #8
@[email protected] had klaus Ward out today who operates a mobile service in Hants Diagnosed a leak on the
Condenser right were the vain meets the main body. Probably due to corrosion of the alloy rather than a stone chip. 250 for the job all in which I am happy with considering some of the dealer prices I have
Heard quoted. Part ordered being done next Monday. Auto Aircon 07973 252531.
Premium Member
Sorted then :thumbsup:..............at least you not chucked money away just having regas that would have vanished into thin air !! tbh for the extra £20ish for a service is money well spent and imo a regas is just false economy thus this is the reason we do not do this in work
SaabScene.com Premium Member
I was gonna say the rad as that's what happened to mine. Got a really good price all in there as I did mine myself and cost me about £160 (£120 for the rad, £40 regas) - Been 2 years as it's still cold as hell, love it - best a/c ever. I also fitted some mesh behind my grill when the bumper was off to stop the chances of any large stones damaging the rad in the future.
Discussion Starter #11
Another update, new condenser fitted, regassed (obviously) but the car is still not blowing cold air. Klaus has changed the pressure switches, checked the clutch, cant find any issues. He can start the aircon using his "probe" and it runs and chills the car, but wont start from within the car (fuses have been checked). I am going to try a calibration later. See if that resolves it. What we both noticed is the LED on the autobutton (on the passenger side) is not working. (It was up to Sunday) thats not a sign of a fault is it ? Anyone any ideas ? If that wont cut it, then its time for a garage, and more money.
Premium Member
below that button is a switch for aircon off check this is not lit
if you press the auto button does this light then come on ?
another quick check go into settings on the sid go to climate settings and check aircon is on or auto your manual will guide you if you don't have one let me know and will post up for you
then let us know how you get on
Discussion Starter #13
Cheers Kez, just been to the car myself to check it out, all the above criteria has been met. Still no chilled air the man said he has done loads of 93 and 95 and never seen this before best he can suggest is an
Electrical fault IE a broken wire. Disregard the auto LED it works, just me being a numpty. Bear in mind he said he can fire up the aircon with his gadget and it chills the car. He has checked everything he can. Even got an aircon service sticker under the bonnet but no chilled air to the cabin. @@[email protected]@
Discussion Starter #14
Looks like its going to be a Tech 2 garage job, just on the off chance does anyone know where the aircon control module is located ?
Discussion Starter #15
Still pursuing this on other boards as well as this, not getting far.
Learning lots about Aircon though :)
Best link of "how it works" http://www.swedishwrench.com/saab_ACC_part_2.htm
(read the part 1 ) So, best I can come up with at the moment is I have no fan action on the front of the car when I turn the aircon on, Still think I will have to Tech2 diags it tho, but just for the moment it will have to wait, I have thrown to much money at this car last week, with 12 months Tax, and 275 bill on the aircon. In the meantime if anyone has any ideas please feel free to give your input.
Premium Member
have you checked the aircon relay ? in the engine bay fuse box
not got any info at hand to whic relay it is as in work but will state in your manual .............if you remove it and put a link accross the corresponding terminals 30 and 87 of the relay holder in the fuse box ( if you look at the relay pins it will have numbers next to them)
does this work ? when you start car and have aircon on
Discussion Starter #17
YES YES YES ! Kez you are the man jumpering
Works ! Ice cold air thru vents :) obviously duff
Relay need to source one now
Discussion Starter #18
Part ordered off the Internet, I had a choice of official Saab Part at 50 odd quid, plus postage, or OEM
Part at 4.60p with free postage, guess which won. Can't believe the aircon is now working after all the
Aggro and expense of last week. It's only through this forum ((you Kez)) that I managed to get it sorted. I have surfed the Internet dry for info on this since last Friday. NOWT ! That being said I am disappointed the guy that came out to replace the condenser didn't pick up on it, and basically left me with it. He has on his aircon blurb "fault diagnoses" well this is one he didn't diagnose :mad: I work in I.T. And if I don't
Fix I don't get paid...still alls well that ends well :thumbsup:
Premium Member
o.k hope the relay sorts the problem and is most likely too :thumbsup:...............if after fitting you find the problem still exists come back and I will guide you further...........I don't understand why he was unable to diagnose this tbh
in the mean time whilst you are waiting for the new relay there is another test you can carry out re switching of the relay and if this proves successful it is certain that the relay is at fault.............
on the relay you will notice 2 other numbers 85 & 86 these are the coil of the relay that energise the relay from a switch which then switches over to make a circuit between 30 & 87
to test the coil the use of a multimeter, 12v buzzer or test lamp will be needed, I will assume you are going to use a multimeter so set it to 12v dc correspond terminals 85 & 86 from the relay pins to the relay base, now insert one lead of the multimeter into terminal 85 and the other into terminal 86, start the car and cycle the aircon switch between on/off with the temp dials set to low..............the multimeter should show 0v or 12v
Discussion Starter #20
Cheers Kez I will borrow a meter from work tomorrow night and play under the bonnet. I will be back.
1 - 20 of 54 Posts
