9-3 7 speaker system can rear amp power 6x9's (currently have 4" sitting in there)
pics below are my useless 4" speakers on rear shelf....
I was wanted to change them to 6x9's as holes are pre-cut see pics...
will my current SAAB AMP be able to handle the 6x9's was looking at some of these:
eBay item number :
111572125790
here my saab amp
So my question is do I just throw the 4" in the bin and use there wiring for the new 6x9's....?
And are what are the 2 pairs or wiring in pic below (green & black/white)
Re: 9-3 7 speaker system can rear amp power 6x9's (currently have 4" sitting in there
Can't see the link from the well known auction site
I think ( and I maybe wrong ) but you require 2 ohm not 4 ohm if your looking .
The amp is designed to handle the 6x9" I've got exactly the same amp as you .
And I've got the 2 paper plates and a pair of 6x9" no problem driving them .
I think a few on here have done the same
What those 2 wires are , they maybe the wiring for the rear seat unlocked sensors , I maybe wrong?
I just used the wires that run to those paper plate type speakers .
Discussion Starter #4
And whats better 2 way or 3 way 6x9's...
cheers
Administrator
if you've not changed out the front 3.5" dash speakers start there..
Discussion Starter #6
3.5" are they easy to change are all 3 front dash speakers same size and Ohm
Discussion Starter #7
One for aerojon
can you have a look at diagram
and answer me what are the left and right channels +/- and shield for on my Nav head unit.....
can I add some sort of Bluetooth music receiver to them pins
