Hi there
I've just upgraded my single CD player (dash mounted - just below the digital air-con unit in my 2005 9-3 Vector), to a 6 CD multi-changer (the model that looks the same, but has 6 buttons beneath the CD slot) which I got from a breaker car the other day.
I can tell that it is connected properly, as when I push on button 1 or 2 on the multichanger unit, I can hear "whirrings" inside it, but nothing actually happens. I cannot insert disc as there appears to be an internal flap that blocks getting a disc in. When I select "CD" on the control unit at the top of the dash, it just reports "NO CD".
Does this new mutli-changer need to be activated with a Tech2? Or is it more likely that the unit is just faulty? (which would be desperatly annoying!) - the single CD unit that I removed works perfectly... or is there anything else I should be doing?
Many thanks in advance for any replies.
