1 - 1 of 1 Posts
These are from a PDF that I have which is 218KB in size - I'm happy to put it up on a website and link to it.
INTERIOR DIMENSIONS
Seating capacity 5
Passenger volume 90.4 cu. ft.
Front headroom (in.) 39.7 (1,008.4 mm)
Front leg room (in.) 42.9 (1,089.7mm)
Front shoulder room (in.) 52.7 (1,338.6mm)
Rear headroom (in.) 37.3 (947.4mm)
Rear leg room (in.) 33.7 (856mm)
Rear shoulder room (in.) 52.9 (1,343.7mm)
Trunk capacity 27.9 cu. ft.
EXTERIOR DIMENSIONS
Wheelbase (in.) 99.4 (2,525mm)
Front track (in.) 57.7 (1,465mm)
Rear track (in.) 57.3 (1,455mm)
Overall length (in.) 175.6 (4,460mm)
Overall width (in.) 66.7 (1,695mm)
Overall height (in.) 57.7 (1,465mm)
Aerodynamic drag 0.35 0.34
Fuel capacity 15.9 Gallons (60 liters)
Drivetrain
Type All-wheel drive
Manual transmission 5-speed manual transmission for all-wheel drive
Automatic transmission 4-speed automatic transmission for all-wheel drive
Transmission ratios
Code:
        Linear    Linear    Aero    Aero
         5 Man    4 Auto    5 Man    4 Auto
First         3.454    2.785    3.454    2.785
Second         2.062    1.545    1.947    1.545
Third         1.448    1.000    1.366    1.000
Fourth         1.088    0.694    0.972    0.694
Fifth         0.780    ----    0.738    ----
Reverse         3.333    2.272    3.333    2.272
Final drive    3.900    4.111    3.900    4.111
Code:
EPA FUEL ECONOMY RATINGS
    Linear          Aero
  Manual  Auto  Manual    Auto
Est. MPG, city  22  23    20    19
Est. MPG, hwy  29  29  26  25
Top speed (mph) 124  117  141  130
Dont forget that US gallons are approx 7 Imperial Pints (4 litres)
Code:
Displacement    2.5 liters (2,457 cc, 150 cu. in.)  2.0 liters (1,994 cc, 122 cu. in.)
Power output    165 hp (123 kW) @ 5500 rpm      227 hp (169 kW) @ 6000 rpm
Maximum torque      166 lb. ft. (225 Nm) @ 4000 rpm  217 lb. ft. (294 Nm) @ 4000 rpm
Compression ratio      10.0:1      8.0:1
Maximum boost pressure      NA      13.5 psi (0.95 bar)
Aspiration    Normal aspiration    Turbocharger with intercooler
Bore x Stroke    3.92 / 3.11 in. (99.5 / 79.0 mm)  3.62 / 2.95 in. (92 / 75 mm)
Ignition/Fuel injection  Dual ignition/multi-point fuel injection  Direct ignition multi-point fuel injection
Arrangement    Horizontally opposed    Horizontally opposed
Valve train    SOHC      DOHC
1 - 1 of 1 Posts
