At some point I intend to fit a 3 bar MAP sensor to my 9k to enable mapping above 1.54 bar .
Anyway in preparation for this I have today taken some readings and plotted some graphs:
Not a problem per se, 'cos I won't be want more than about 1.8bar. But it does seem like I've been sent the wrong sensor.
Now, all I have to do is work out how to get this mapped into my ECU...
Hi Bubbles, I think you have been sent the right sensor. The reason i think this is because a MAP sensor measures vacuum as well as pressure, so 2.2 + 0.9 is 3.1 by my calculations. I think this sounds about right.
You even said that you wanted to go beyond 1.54 bar boost that the standard 2.5 bar mape sensor provides.....
My OEM Mapsensor is faulty. Is it OK to change to the 3 bar one without making any other changes. I know that there will be no benefit without re-mapping the ECU to recognise it but wondered if it would run as normal.
I expect it will throw the air/fuel ratio out completely. From the above graphs, the ECU will have to know you have a 3.0 bar MAP sensor fitted to the car, otherwise it will not interpret the signal correctly. For example, when the pressure is 0.5 bar, the 3 bar sensor will output 2.25V. The ECU, calibrated for a 2.5 bar sensor, will interpret that voltage as 0.3 bar manifold pressure, because that is the manifold pressure that will cause a 2.5 bar MAP sensor to output 2.25V.
Remember that a Trionic 9000 has no air-mass meter so the air-mass is calculated from other parameters, of which the manifold absolute pressure is a very important part.
Thanks for the explanation Bill, I understand it now and the graphs help. I'll save the 3 bar for another day.
