if I change into second quickly from first, I get a nice crunch. it does not happen if I change slowly into second, and it does not do it in any other gears if I change quickly.
Any ideas ?
I'd go for 2nd gear synchro being worn. 2nd often get well worn
A synchro ring is about £21 + vat
Labour is a good bit more!! (remove, strip, rebuild, replace ....
Also, while your down there, consider a clutch and slave cylinder change.
