Esteemed Saab collective,
I have a UK spec 2011 TTiD Linear convertible that I have had from new, as it is ageing it is starting to throw up some curious electrical issues (at least I think they are electrical).
I am sure these will have been covered way before I joined the group yesterday but I hope you will bare with me.
The first problem I am getting is the Drivers door fails to lock using the remote, the alarm still arms, and has cought me out a few times but at least I know it works ;), and the window functions correctly as does the folding mirror. What diagnostics could I do to try and identify the fault? I do have a code reader but it is not detecting any issues, also the self check the car does prior to starting always reports OK. I have read that I will need to replace the door lock entirely, is this correct? This issue does seem to seasonal as well, only happening in the winter months.
The next problem I have is the horn. Due to the fact I am a careful driver (yeh! right) I rarely require to express my displeasure with the poor driving of other road users, however when that rare occasion arises you can imaging my frustration that when I bang the steering wheel all I hear is the thud of my hands on the wheel. Bugger! I am sure it is only a dirty contact on the horn mechanism but I am unsure of how to access it and I am reluctant to tamper with the air bag. Can anyone suggest a solution that I can try? Or explain to me how I can remove the centre of the steering wheel (where the air bag is) so that I can access it. I have done the 'normal' things like checking the fuse and I have even directly powered the horn and it works very well, which is why I believe the steering wheel contacts are most likely to be at fault.
I look forward to reading your sage advice.
Kindest regards,
Daz H.
Airbag removal see below , of course safety first , ( don't leave your key in the ignition )
Remove both terminals on battery , and leave for 10-20 mins .
https://m.youtube.com/watch?v=TzJW3A1SvFg.
As for door lock failure seems to be a bit of a common issue , you could try removing the multi plug in the door frame make sure no connections are corroded .
If you can remove door panel make sure there's no water ingress and check connections in that area .
Premium Member
Welcome,the door will more than likely be the actuator starting to fail...did the horn work at the last MOT..have you checked the fuse..
Thanks for the responses guys.
The horn must of worked at the last MOT as it passed! I have not had to us it this year but the fuse is still good.
I will watch the youtube Video once I get home, my work system won't allow anything useful to come through. I was surprised it allowed me onto this site.
Chin, chin.
