I think my steering wheel lock is starting to go. “Steering wheel malfunction” randomly comes on, sometimes when I’m driving and sometimes when I try and start the car. I can reset the fault several ways and I’m going to get it looked at ASAP but I would like to know what the problem is and what the fix is?
Thanks in advance for any info!
It could be many things unfortunately.
The solenoids on the steering lock or wiring/comms faults between the various modules.
Tech2 is the only tool that can help diagnose.
Can also be the ISM but as it happening whilst driving its likely a comms fault imho.
Yeah. I kept messing with it till on a series of hot days finally showed battery bad. Replaced it. No more misc intermittent issues. 08 9-3 CV w/~50k.
As Stated Above Replace the battery in the car and give the vehicle a good running
Electric seats rear defroster and short trips will cause this
I kept getting Possible Steering Lock Malfunction ... coming up sporadically on my 2010MY 9-3 2.0T convertible, always resetting itself. Spoke with Martin of Central Saab Specialist in Bonnyrigg - he said likely the ISM, they get quite a few of these. Took it in and they confirmed the diagnosis and fitted a new ISM. All good (1 month).
Jonno
You need to remove and leanup your ignition switch moddule. I have a video on youtube on how to to this. It should come up in the first coupe of search results
