1 - 1 of 1 Posts
Not sure if this is the right place, but figured I'd share my data. Unfortunately my brother recently erased almost the first two years of ownership during which I racked up quite a bit of mileage between my old job and ex-girlfriend taking it on a couple far weekend trips while I was out of town. In any event, here is all the data I have maintained since 3/19/2010. For anyone wondering, I have used exclusively Mobil1 0W-40 and ATF 3309 since I purchased the car.
Service Records: Total Cost $6,181.38
Record #Service TypeMilesDateCost
1Oil Change854813/19/2010$60.09
2MD State Inspection856943/22/2010$75.00
3Battery865034/11/2010$155.00
4Lip Spoiler 866204/16/2010$107.00
5Air Filter875295/13/2010$19.00
6Spark Plugs875995/15/2010$31.00
7MD Emissions Test877735/21/2010$14.00
8Cabin Air Filter879925/27/2010$18.00
9Oil Change881976/4/2010$53.15
10ATF Drain/Fill902888/2/2010$178.00
11Oil Change906558/18/2010$61.00
12Transmission Additive908918/25/2010$48.00
13Tire Balance/Rotation908918/25/2010$55.00
14Oil Change9371311/18/2010$61.00
15Wiper Blades956531/7/2011$28.00
16Oil Change970253/12/2011$58.00
17ATF Drain/Fill971393/17/2011$187.00
18Oil Change1003067/12/2011$45.25
19Oil Change10342610/22/2011$61.00
20Front Brake Pads1055191/4/2012$85.00
21Power Steering O-Ring1055191/4/2012$145.00
22Air Filter1062192/7/2012$20.00
23Right Position Light1062192/7/2012$1.00
24Oil Change1070943/20/2012$41.29
25Rear Brake Pads1079855/17/2012$85.00
26Oil Change11159410/9/2012$41.29
27Center Wash Nozzle1149953/14/2013$15.00
28Oil Change1162094/30/2013$41.29
29Cabin Filter1186717/23/2013$17.00
30Spark Plugs1186717/23/2013$12.00
31Serpentine Belt1198958/15/2013$50.00
32Brake Flush1198958/15/2013$70.00
33Oil Change1205678/25/2013$31.47
34Brake Rotors12202110/18/2013$150.00
35Drivers Side Headlight Bulb12212310/22/2013$115.00
36Passenger Side Headlight Bulb12331412/20/2013$103.00
37Passenger Side Marker Light1249972/21/2014$1.00
38Tires1250612/24/2014$520.00
39Oil Change1250792/24/2014$48.00
40Wiper Blades1268255/3/2014$20.00
41Oil Change1293408/3/2014$23.56
42Air Filter13229011/17/2014$15.37
43Power Sterring Reservoir Cap13229011/17/2014$5.00
44Replaced Four Coil Packs13231211/20/2014$398.00
45ATF Drain/Fill13231211/20/2014$178.00
46Tire Balance/Rotation13231211/20/2014$49.19
47Spark Plugs13246511/27/2014$14.00
48Oil Change1338583/1/2015$23.56
49Alignment 1359865/6/2015$112.00
50Tire Balance/Rotation1359865/6/2015$50.00
51Left Front Turn Signal1371857/22/2015$5.99
52Oil Change1377948/2/2015$31.47
53Tire Rotation14098911/11/2015FREE
54Oil Change14215612/27/2015$23.56
55Vaccum Pump Gasket1432982/22/2016$112.00
56Strut Mount1432982/22/2016$152.79
57Shock Assembly (x2)1432982/22/2016$228.79
58Coil Springs1432982/22/2016$281.82
59Windshield Wipers1436563/5/2016$8.00
60Battery1448095/5/2016$119.91
61Air FIlter1451665/18/2016$15.49
62Oil Change1464227/11/2016$28.00
63Tire Rotation148,0739/18/2016FREE
64Right Side Brake Bulb148,0739/18/2016$2.18
65Cabin Filter148,22010/4/2016$9.59
66Left Side Brake Bulb14925011/1/2016FREE
67Front/Rear Brake Pads14925011/1/2016$122.00
68Right Rear Caliper14925011/1/2016$235.00
69Oil Change15058012/18/2016$27.49
70ATF Drain/Fill1543395/25/2017$108.92
71Tires1544205/28/2017$560.85
72Oil Change1548616/12/2017$29.00
73Wheel Bearing Hub Assembly Right Rear1574199/1/2017$283.02
74Position Lights15801710/26/2017$2.76
75Oil Change15937511/12/2017$28.00
76Center Armrest Replacement1640114/6/2018$52.48
77Oil Change1640114/6/2018$28.00
78Windshield Wipers1641694/11/2018$19.82
79Air Filter 1641694/11/2018$11.62
1 - 1 of 1 Posts
