1 - 1 of 1 Posts
Hope someone can help me. 2007 9-7x 4.2L
CEL on dash, code reads 0411
replaced secondary air pump under car, solenoid on engine, and relay under car
fuses both good
I clear the error code and light comes back on within 24 hours.
Can i wire this pump to run continuously without causing any damage and if so will that keep the dash error light off?
What else can the problem be? Why is this pump even needed, the car runs fine.
Any help is much appreciated, jake
1 - 1 of 1 Posts
