Hey, I apologize if this has already been discussed but title says most really, it accelerates perfectly fine as long as I don't press down to far, changed spark plugs, clean air intake and manifold I believe, and then did a compression test on engine, that came back fine. Thank you guys in advanced!
One or all of your coils could be bad If they are white top for sure
Get a tech2 see what cyl is misfiring and replace or replace all
All 4 coils can be changed in 15min or less with less than $10 in tools
Start to finish and washing your hands
This should have been the first thing done
Try opcom easy yo buy on that well known auction site,
And an old laptop.
You did the right thing and started with the simple things first .
Coil packs are not cheap and the coil packs need to be mishibushi I think
