Hi. My 2006 face lift 9-5 wont let me switch off the glass break sensor when the key is removed from the ignition and the CLR button pressed on the steering wheel. The CLR button is working so clueless as to why this wont work... any ideas?
That is certainly the case for earlier models but I believe that Dame Ednas use the CLEAR button instead. With the key out of the ignition, press and hold until "DOOR ALARM ONLY" is shown on the SID display.If I remember correctly, the glass break and tilt sensor are isolated by pressing the night panel button[/b]
Interesting thought. It would seem that some models come without glass break or tilt sensors, and these can be added afterwards. When they are added, Tech 2 is used to enable them in TWICE.Are you sure it actually is activated? I was under the impression that it can be de-activated under Tech II. (Previous owner maybe?)[/b]
Ah, was probably disabled when they took the blue flashing lights off............ its ex police so..[/b]
