Hi there,
This is my first post, although I have been trying to glean words of wisdom from this site. I have had the Saab for about 6 years and unfortunately it has been unused for most of that time. I took the cover of a few months ago and got a new battery and it started up no problems at all. However, I had issues to fix -broken inside drivers side door handle. So took door of and 3D printed some bits and pieces and plastic welded to nearly get it going. My problems seemed to start about then.
Prior to that Radio worked and Top would work fine(maybe coincidental?) From then on starting became intermittent until now-Cranks but no start. With the key it will usually only give one effort to crank but if key is released from start and you try again then nothing. I have tried by-passing key and direct 12v to Relay. Cranks over easily but no start.
What have I tried:-
My underlying thought is something simple like a blown fuse a short or bad connection somewhere?
I recently bought a ODB11 scanner Foxtell F1000B. It gives me a P0601 code
it shows P0601 $07E8 Generic
Internal Control Module
Memory Check Sum Error
Am I getting this code because (as I said fuse, short etc and feed is not getting to a Control Module)?
Apart from getting an Auto Electrician in to Diagnose any suggestions? Would be very much appreciated.
Cheers all
Trev
What have I tried:-
- tested for a spark and looks like no spark - but no spark on any coil so I didnt think all 4 would go bad together.
- tested voltage to coil and got test light to light up.
- Didnt test for signal voltage- not totally sure how but need a helper (wife) for that.
- When key turned on couldnt hear fuel pump primeing also only dribble of fuel when bleeder is pressed.
Cheers all
Trev
