Hello forum!
I'm concerned about the well being of my engine.
It has about 240k Km
A couple days ago I went to a mechanic to have a look below the car as it was making a weird noise driving over bumps.
That problem is solved, what scared me was the amount of oil I saw that was below the engine when the car was in the elevator.
It is not dripping oil, the level is still good but it was a mess.
I also noticed that the car was making a bit of a greyish/black smoke but not that much to concern me.
I went to a car wash and asked to clean the engine so that tomorrow I can leave it in the mechanic to have a look.
Today I also noticed that the coolant reservoir seems a bit low. To be fair I made about 1500km since I topped it up a month ago, most of them in rush hour traffic, the car doesn't go over the middle of the temperature gauge but gets there in about 10/15min.
My worst fear is that I have a blown head gasket.
Could it be??
I don't see anything weird in the oil dipstick or any difference in the colour.
The coolant reservoir seems alright as well.
I can see that the valve cover gasket seems to be leaking but I'm not sure, but that gives me hope that I may have a leak there and the coolant may be leaking somewhere I don't notice.
Is it usual for the 2.2 to blow the head gasket???
Any info is appreciated.
Hello Paulo
First thing is " Don't panic !!!!"
Grey / black smoke normally means it's over fuelling.
So I would start by looking for either a boost or air leak
Oil is a messy substance and a minor leak can look bad .
Get the engine bay cleaned down with some degreasing agent ( not a steam clean ) as that can cause electrical wobbles .
If you are concerned about head gasket then a sniff test will put your mind at reast
Discussion Starter #3
Thanks for the reply.
My mechanic should be able to have a look at it tomorrow as he was busy today..
Hopefully it's not that bad, I'll let you know the outcome
Discussion Starter #4
Turns out the parts company that my mechanic works with closed due to the virus, so I will only take care of the car once things go back to normal :(
