1 - 1 of 1 Posts
A new issue has occurred when trying to lower the roof on my 2001 convertible. Everything starts ok apart from the windows are no longer dropping. When the roof get to a vertical position, that's when it stops. Lowering the windows allows the roof to continue to fold away as normal. All the windows work perfectly, with the individual buttons and with the one that lowers all 4. What I have started doing is lowering the windows before I open the roof and all works as it should. Interestingly, I do not have the same issue when putting up the roof as when doing so the windows lower as they should.
It's not the end of the world but just a bit irritating and I can't find any solution on line. Also I'm hoping that it's not the start of a bigger problem.
Thanks in advance
1 - 1 of 1 Posts
