1 - 1 of 1 Posts
After a Tow and Fuel pump change my 2000 Saab 9-5 Aero goes into limp mode once the AT shifts into 4th gear. My check engine light comes on also at the same time as the transmission warning light. When I check for codes there is only an Evap leak code. When I clear the Evap code the transmission warning light goes out also. Is this an issue generated by the tow or the fuel pump change or something else? Thanks.
1 - 1 of 1 Posts
