Hi Guys
I have read the archives, and have come to the conclusion that my wastegate is not opening causing the boost to go way into the red on full throttle and it then cuts out. My first step was to check the actuator rod which moves back and forward quite freely, but the symptoms are still the same. How far should the rod move? and if it moves can it still be a problem with the wastegate. Should I remove the turbo and clean out the wastegate, or is there something that ca be done with it in situ?
