Hello all,
Could anyone give me there opinion on the following please?
My 1999 2.2 TiD had been running well (122K) with no lights, power or starting issues...
Driving home up steepish hill I accelerated after slow coach in front turned off and my car just died... bit of a shock for me and guy behind!
Managed to coast to side and tried to restart - turned over but nothing else. Engine light now on.
Tried to see if any hoses had collapsed and general look over but could see nothing. Still wouldn't start - parked on incline.
AA came out - no fuel at injectors. Took me back home and dropped car at local garage.
They have diagnosed fuel pump failure... my worst case scenario.
Bearing in mind the suddenness of the breakdown is this the most likely possibility?
I had had no starting problems, so probably isn't leak off pipes - but holding out hope it might be something easier and cheaper to fix...
Any tips on diagnosis - not sure that local garage has Tech 2 gear...
If it is the pump does anyone have a source of recon VP44 pumps? I feel that the cost of replacement may make it an uneconomical fix as it would be more than the car is worth...
Oh well, you take your chances with high mileage cars...
Thanks,
Bolts
Thanks,
Bolts
