Hello!
I have a 99 9-3 SE. I've determined that there's an issue with the wiring to my 3rd Injector, similar to the issue described here (https://www.saabscene.com/forum/threads/130362-cylinder-injector-3-open-circuit-error).
However, that thread is for a later model, as well as for TiD, which my 9-3 isn't. Does anyone know if the part mentioned there (93189918) is compatible with my car, or have any other suggestions for parts I could get?
Thank you!
(For those curious, I figured out the issue by testing the voltage to ground of each wiring harness. All 4 had the same reading for the hot side, but the 3rd had a way high reading for the ground side, which should've been 0. I also tested the resistance of the plugs, which were all the same, and listened to the injectors firing, which all sounded good)
Have you probed the wiring back from the connector to establish a break or corrosion (high resistance) problem.
I usually do this type of thing sticking a tiny pin in the wire at various points back through the crimps etc
Best bet is probably a breaker........if its definately the wiring.
Any Tech2 codes to work with?
Use the troubelcodes to troubleshoot using the WIS (Tech2 section on Saabcentral)
