141 - 160 of 204 Posts
Discussion Starter #145
First upholstery job ever. Center arm rest cover redo. The zipper panel is the only one that has not dried and shrunk. It is being reused with new vinyl. The top leather panel is beyond help.
53101
53102
Discussion Starter #146
The cover was a bust. I'm going to use it just so I have something on it but it's horrible LOL.
Discussion Starter #147
I may be getting these.
Discussion Starter #150
The arm rest cover was a bust. I ended up ripping the vinyl installing it. I will be working with L-Seats soon to get the CDE back seat pattern copied in original color leather. The 9000 'contour' front seat cover set is available right now for $350 but I don't see an arm rest cover and they don't have the rear seat pattern yet.
Discussion Starter #151
Rear seat lift repaired with replacement gears. Front lift gears are curing still, rebuild later this week and temporary reassembly to test gear durability.
Upon initial torque and strike tests the resin gears are just as sturdy as nylon 66 but slightly stiffer. Will see how they peform with my 210lb butt in the seat.
53103
53104
