81 - 89 of 89 Posts
Discussion Starter #81
Video on jack point repairs coming soon. Almost done with the driver side repairs. Have to make a patch for the big hole there. Weld grinding and seam sealing this weekend in preparation for rear suspension re-installation. Still waiting for rear rotors and brake pads to come in but I can get the main suspension and hubs back together.
Discussion Starter #82
52921
52922
Seam sealer going on and suspension re-install has begun. Still waiting for rear brake parts.
Discussion Starter #83
I've definitely gotten better with the gas mig based on the welds on the panels in the bottom pic. It almost makes me want to grind it all back down and re-weld it. ALMOST.. Not happening though. LOL
Discussion Starter #85
If I only had that EBC brake kit. Dealer is still waiting for it from UK. Always someone holding up progress.
52928
Discussion Starter #87
LH side jack point and floor repaired. The patch I made ended up being too short as the MIG obliterated floor metal that looked ok. I had to patch that hole on the end after I found decent metal. Just have to treat and coat the underside now.
52930
52931
Discussion Starter #89
Giving the evap box some love. Fiberglass and plastic are not good buddies. Permanent fix done. The recirc door frame is busted too. Still pondering a fix.
52934
52935
52936
I doubt the factory put dents in the tubes like that. I sure hope it does not leak!
52937
81 - 89 of 89 Posts
