When you switch on the system ,does the A/C compressor clutch cut in ? If not, I agree with Derek, and would get the system re charged. There is a pressure switch which cuts electrical power to the compressor clutch if the refridgerant pressure drops too low. The compressor has its own oil supply - suggest this is checked at the same time
