1 - 1 of 1 Posts
With the help of my Bently manual I removed the gear lever housing and removed the broken ignition lock barrel.I replaced it with a used one that was cleaned and the key moved back and forth freely.When I placed it into the gear lever housing and replaced the ignition switch,the ignition key would not spring back from the start position.I replaced the ignition switch with another used one.No change.On further investigation I noticed that the lever action between the ignition lock and the ignition switch ( located on the underside of the lever housing) only moves when pressing down on the key.
I thought that I would seek any input before putting it back in the car.
Thank you
Grant
1 - 1 of 1 Posts
