hello this is my first post on this forum, can anyone help with my problem please 07 saab 93 diesel ,every say 2 to 3 hundred miles when driving, i start to smell what is like un burnt diesel and it gets worse, pull over then need to rev the tits out of the engine, clouds of grey smoke pumping out of exhaust may take 5- 10- 15 mins to clear then ok until the next time , is there a pipe going to the dpf that would allow diesel into the exhaust system have stripped and cleaned the egr valve and no change, its getting embarrassing now .anyone help please thanks
Administrator
what sort of mileage/trips are you doing..
Hey, I was having the same issue on my 93 not too long ago because I only do short journeys and I was told to try using a dpf cleaner. it only cost me like 6 quid and seemed to work. I think I found the one I used from the link below
Administrator
short journeys is a no no with modern diesels,think the dpf as a self cleaning oven..
