1987 9000 turbo climate control problem
Results 1 to 5 of 5
Thread: 1987 9000 turbo climate control problem
    my saab is a 1987 9000 turbo and i know it has climate control, I set it to low but it does nothing I was just wondering what some other peoples thoughts on this were if I'd need a new A/C unit or what..pls respond, thanks.
    Jun 2000
    Forfar,Angus Scotland
    1,243
    Re: 1987 9000 turbo climate control problem
    The A/C system probably needs re-charged
    When you switch on the system ,does the A/C compressor clutch cut in ? If not, I agree with Derek, and would get the system re charged. There is a pressure switch which cuts electrical power to the compressor clutch if the refridgerant pressure drops too low. The compressor has its own oil supply - suggest this is checked at the same time
    thanks alot, i'll have to go check that out life in warm climate with leather and no A/C really stinks =/
    Guest
    Guest
    Hi,
    my 1990 Turbo has the same problem. The AC doesnt cool the car down, its almost heating so its nearly impossible to drive without opening a window :-(. I havent found out the problem too.
  7. Remove Advertisements
  1. Climate Control Problem
    By mr_Flash in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 03-30-2010, 03:18 PM
  2. climate control problem
    By swdxu010 in forum Saab 9000 (1984 - 1998)
    Last Post: 11-17-2008, 11:13 AM
  3. Odd Climate Control Problem
    By Gixer in forum Saab 9000 (1984 - 1998)
    Last Post: 12-16-2002, 10:13 AM
  4. Odd Climate Control Problem
  5. 1987 9000 turbo climate control problem
    By Jack in forum Saab 9000 (1984 - 1998)
    Last Post: 09-15-2000, 06:24 PM
