saab 9.3 aero 2l 57 plate uk - coolant leak
Results 1 to 6 of 6
Thread: saab 9.3 aero 2l 57 plate uk - coolant leak
  1. #1
    I am having problems with a leak on my 9.3.
    I have just replaced one of the heater hoses after seeing a leak. Everything i have put back on is dry.
    So i top it all up... squeeze the hoses to help get any trapped air out of the system... then drive for circa 3 to 4 miles and the coolant warning comes back on as the collant level has dropped... this has happened 2 or 3 times...
    The only dripping i can find is shown in the attached video kind of a flash in the middleof the video. Initially i wondered if it was moisture from the aircon but now i am not so sure....
    Looks like there have been a couple of bodges done to the car in the past but i am changing that as i find them.
    Has anyone seen this dripping before? Is it aircon moisture or something
  2. Remove Advertisements
  3. #2
    Saab Junior
    Join Date
    Aug 2019
    Location
    NC, USA
    Posts
    26
    Re: saab 9.3 aero 2l 57 plate uk - coolant leak
    Check your oil level to rule out a head gasket problem. Hopefully you don't pull up milkshake on the dipstick.
  4. #3
    Thanks... should have thought about that as a starter for 10...
  5. #4
    Hello and a warm welcome aboard the good ship saabscene Ghost Town .
    if it was the air con then that would be dripping round about from the middle at the back of the engine ( nearest the fire wall )
    i would try a pressure test on the cooling system to see if there is any leaks from hoses .
    you say it looks like there have been a couple of bodges done are they on the cooling system
    an old way of checking head gasket failure was ( and this is with a very stern safety warning )!
    is to start the car . Warm it up take expansion cap off and sniff for smell of fuel .
    also check expansion cap itself , sometimes they fail .
    PS I cannot see your video anywhere.
    is your car manual or automatic?
  6. #5
    Thanks... initially it looks like clear water and it is in that location... but unless its air clearing from the coolant system where i have worked on it.. i am at a loss.... i did slightly better than my usual mechanic who could see anything...
    The bodges were putting some sort of sealent around a heating hose rather than either changing a hose or the rubber washer inside it...
    They have also cut hoses when the ends were perishing but probably cut them too much and its made everything a bit too snug
  7. #6
    Its manual.. and i ve never been an on line genius so might have added it wrong or it might have been too big.
    No smell of fuel.. i dont think its the head gasket but i didnt check and thats an easy thing to do.... school boy error...
  8. Remove Advertisements
