Electric mirrors
Results 1 to 8 of 8
Thread: Electric mirrors
    Saab Fan
    Jun 2003
    Herts
    53
    Electric mirrors
    The adjustment on both external mirrors on my 9-5 saloon have stopped working. I've checked things as far as I can (just the fuse really) and can't find anything obvious. Any ideas?
    Also, and it's probably completely unrelated, the front heated seats don't appear to function.
    Re: Electric mirrors
    Could be the switch itself
    Agreed. If they've both stopped working at the same time it's unlikely that it's the mirror motors. If the fuses are OK I'd replace the switch with one of the cheap copies on eBay.
    But if it is the motors then copies can be had cheaply off The Bay too.
    Saab Fan
    Jun 2003
    Herts
    53
    Thanks both, I’ll give that a try. The switch is a Vauxhall part so there should be plenty of them available.
    They look uncannily like the vectra B switches
    My own conundrum is that on the passenger side down is up, up is down, left is right, right is left. Tried swapping the wires on the back of the motor and solved the left/right but any further thinking about the problem just made my brain hurt.
    Saab Fan
    Jun 2003
    Herts
    53
    In the distant past, I drove a Cavalier and an Omega which both had something very similar.
    Anyway, I’ve fixed mine. I found another thread on here that suggested taking the switch apart and cleaning it. With a bit of fine abrasive paper and some contact cleaner I did that and now all is well.
    Super Moderator
    Oct 2002
    Kippen, Stirling
    2,681
    johnl,
    As rich suggests, it is probably the up/down,left/right switch that is defective. You usually find that, if you wiggle the switch in each of the 4 positions and the mirrors will move haltingly. Prise out the switch and gently take it apart. DON'T use sandpaper. I use a little pure alcohol ( vodka or gin works fine ) on the end of a cotton bud. Re-assemble and it should work OK. Almost always the cause.
    Paul @ Kippen
  10. Remove Advertisements
