TTiD Coolant leak
Results 1 to 4 of 4
Thread: TTiD Coolant leak
    Saab Nut
    Dec 2001
    FL370 or in a SAAB
    300
    TTiD Coolant leak
    Have a small coolant leak (needs topping up about very 4000 miles)
    Seems to be coming from rear of engine but very difficult to see exactly where
    The engine block behind the starter is damp with coolant
    Anyone have experience of this?
    Inlet manifold or oil cooler ?
    Ive checked the EGR cooler and all dry underneath
    Re: TTiD Coolant leak
    Hello Saabpilot could be the inlet manifold as they are made of plastic .
    also the EGR cooler runs from the back to the front of the engine it is a large component.
    I would be inclined to get it pressure tested to assertain exactly where the leak is .
    Saab Fan
    Dec 2014
    Hertfordshire
    70
    Quote Originally Posted by SAABPILOT View Post
    Likely inlet manifold. Seems a relatively common complaint. Leaks at the alternator end of the inlet, above cylinder 1. The plastic seam of the inlet fails
    Saab Newbie Warren&Zoe's Avatar
    Aug 2017
    Stoke-on-Trent
    15
    Hi I have exactly the same problem but have to top up every 100ish miles, I can see the coolant burning off on the exhaust and signs of it running down from above the oil cooler but can't see the source, have had it pressure checked but still couldn't see anything, also not long before 8 got the car it had the inlet replaced
  6. Remove Advertisements
  1. 2011 9-3 TTiD coolant leak
    By Maytrix in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 10-15-2017, 06:25 AM
  2. TTiD coolant leak
    By dantm800 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 07-15-2015, 05:22 PM
  3. 08 93 TTiD Coolant leak
    By spacehead in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 07-14-2015, 05:36 PM
  4. TTID Coolant leak into EGR valve
    By swal87 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 11-29-2013, 01:22 PM
  5. Ttid coolant leak?
    By markbar in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 06-07-2013, 07:20 PM
