Ionization sensor detecting knock malfunction
Results 1 to 2 of 2
Thread: Ionization sensor detecting knock malfunction
  1. #1
    Saab Newbie
    Join Date
    Mar 2017
    Location
    New Jersey
    Posts
    3
    Does the Ionization Sensor have anything to do with error code p0325? Does the IS detect knock sensor malfunction?
    I have a 2006 SAAB 9-3 4cyl 2.0T with a B207R engine. (8th VIN digit is a Y). I'm in the USA. The VIN indicates the car was built in Trollhatten, Sweden.
    A mechanic is telling me the Ion Sensor is bad and replacing it will make the code go away. I'm not so sure.
    History is that that mechanic replaced the ECU because of an A/C issue. Turned out that that ECU was a used one even though the bill was for a 'NEW ECU'. Only after the replacement, did the p0325 came up along with p0300 and p0172. That mechanic who did no diagnostics told me that it needs new spark plugs and coils. I didn't do that because he ran no diagnostics and his suggestion was just a 'that should work.'
    Another mechanic ran diagnostics and told me the problem was that the ECU is bad and needs replacement.
    I replaced the plugs with factory recommended NGKs, which temporarily eliminated the 3 codes, but p0325 came back.
    I replaced the ECU with a used one and had it reprogrammed. Don't ask if it was reprogrammed or just married to the engine as I don't know. Problem there was that even though the ECU had the same part number, it was from a 2005. That created other codes I need not go into since they are unrelated to engine performance.
    Sued the original mechanic who agreed to make things right.
    I bought another used ECU from a 2006 with the same engine. Donor vehicle also had a Y in the VIN. He is installing this ECU and the original programmer will program this one. I expect (hope) this will eliminate the p0325. But now the mechanic says the code comes up because the Ionization Sensor is bad and needs to be replaced because the Ion Sensor also detects knock. The engine runs fine despite the codes.
    So, back to the original question: Does the ion sensor have anything to do with the p0325 code and would a bad IS throw a code for engine knock sensor malfunction?
  2. Remove Advertisements
  3. #2
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    5,038
    Re: Ionization sensor detecting knock malfunction
    The ecu needs to be added using tech2,also the software on the ecu needs to be checked that is is the right software for your engine code(in your case R)..
    My 9-3 audio,2 x cd changers,aux-in & Bluetooth audio streaming..
    Buy cheap pay twice..
  4. Remove Advertisements
  1. Tech II fault code ((ionization.....) i forgot)
    By faceplant in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 06-21-2010, 07:07 PM
  2. Ionization Gap Sensing
    By California Saab Tuner in forum Saabscene: Performance
    Last Post: 09-10-2003, 04:59 AM
  3. knock knock
    By estrop in forum Saab 9000 (1984 - 1998)
    Last Post: 05-29-2003, 06:03 PM
  4. Knock knock.......
    By milleplod in forum Help, Advice, Saabs and Motoring
    Last Post: 02-15-2003, 03:30 PM
  5. knock knock!
    By stigglett in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 01-22-2003, 02:10 PM
