Xenon Left Beam Failure - Light works but doesn't shut off
Results 1 to 6 of 6
Thread: Xenon Left Beam Failure - Light works but doesn't shut off
  1. #1
    Hello everyone...
    I have an 04 Arc convertible with Xenon 'Left Beam Failure' on the the SID however the bulb is working but doesn't shut off after the car is turned off. I have to disconnect the battery so it doesn't drain the battery. I swapped all of the components from the right side and the same thing happens so leads me to believe that the problem does not lie in the headlight housing, ballast nor the igniter, Its kindda like a stuck relay. Is this something a Tech2 can remedy?? Any ideas?? Please help. Thank you
  2. Remove Advertisements
  3. #2
    Re: Xenon Left Beam Failure - Light works but doesn't shut off
    Hello and a warm welcome aboard the good ship saabscene RY595.
    i shall stick this in the relevant workshop section.
  4. #3
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    5,043
    The uec(where the fuses are)has gone south by the sounds of it..
    My 9-3 audio,2 x cd changers,aux-in & Bluetooth audio streaming..
    Buy cheap pay twice..
  5. #4
    Thanks for the quick response! Can I swap it out or does it Need to be married with a Tech2??
  6. #5
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Peterborough,Cambs,UK
    Posts
    1,113
    Tech2 needed,however if you can get the fault code you may be able troubleshoot the error first using the WIS and wiring diagram.
  7. #6
    Just picked up an UEC from an 05 Aero vert at the scrap yard. In my case this was a Plug and Play procedure, all works normal now, No Tech 2 needed. Aerojon >>Thank you for pointing me in the right direction.
  8. Remove Advertisements
  1. Xenon left dipped beam failure
    By Foxtonrams in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 01-11-2016, 12:57 PM
  2. Main beam works but dipped doesnt!
    By james coughlan in forum Classic Saab 900 (1979 - 1993)
    Last Post: 09-26-2010, 07:39 PM
  3. central locking works when you shut the door
    By miloollie in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 04-14-2010, 07:26 PM
  4. Left Low Beam Failure
    By dico in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 11-25-2009, 05:08 PM
  5. Boot lid doesn't stay shut... whats up !
    By Blayne in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 06-03-2007, 11:13 AM
