Engine Management Light
Results 1 to 3 of 3
Thread: Engine Management Light
    Hi
    My engine management light has been on for the last 5 years (P1109 -0F Swirl Actuator Malfunction) but since the car runs fine the garage advised ignore it , this advice has worked for 5 years but now the new MOT rules state
    "Engine Management Light is now a major fail. It must come on with the ignition and then turn off when the engine is started."
    So after advice on what to do its a 2006 93 z19dth 16v 150 with a hirsh map to 175.
    I have already cleaned the EGR valve, is the sensor reading the movment of the actuator arm (in which case can I disconnect it(how)).
    Or do I need to replace the actuator arm, the bar itself seems to be stuck in the open position probably why its never affected the running of it.
    Any help appreciated (not done much with cars but dont want to lose a perfectly good car 150K on clock)
    Dec 2003
    Peterborough,Cambs,UK
    1,132
    Re: Engine Management Light
    The actuator motor lives on the underside of the manifold with a dumbell shaped rod connecting to the swirl flap mechanism.
    If the flaps are simply jammed or fixed as a result of the remap then the feedback position at the actuator may be incorrect.
    A simple solution to check this is to pop off the connector undeerneath which in theory would allow the actuator to move back and forth
    and the car is then non the wiser....the fault should clear unless the actuator solenoid itself has failed or there is another electrical reason.
    https://i.imgur.com/8Cki6WX.png
    Unfortunately its not easy to get to the actuator due to its location the oil catch can and bracketry are in the way at the back of the engine block.
    Surgery from the top isnt easy.
    Alternatively you may be able to fish in a coat hanger lying under the car and lift one end of the dumbell rod away from either the actuator or the swirl rod end.
    This is what the connector looks like and probably 3ins long with simple ball and socket connection at each end offset.
    https://www.ebay.co.uk/itm/SAAB-95-9-5-06-10MY-1-9TID-Z19DTH-INLET-MANIFOLD-SWIRL-ACTUATOR-LINK-BAR-ROD-NEW/332594910327?epid=719482004&hash=item4d70339477:g: UTcAAOSwNGRas4hd
    https://www.vectra-c.com/forum/showt...ect-motor-link
    https://www.youtube.com/watch?v=rMMqlKimQwc
    Dec 2003
    1,132
    Before I forget the other option would be to get it mapped out......if none of the above helps
  5. Remove Advertisements
  1. Engine Management light on + TCS light on 9-5 Aero
    By saabheaven in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 08-08-2008, 03:14 PM
  2. Engine management light
    By GASGAS249UK in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 03-06-2005, 06:46 AM
  3. Why is my engine management light on? 2.2 TID SE 2001
    Last Post: 01-20-2005, 01:59 PM
  4. Engine Management Light - Please help!!!!
    By WayneJ in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 07-18-2004, 02:18 PM
  5. Engine Management Light
    By Arctic in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-21-2003, 06:18 PM
