2008 saab 93 tid limp problems
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: 2008 saab 93 tid limp problems
  1. #1
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    2008 saab 93 tid limp problems [updated]
    hi guys
    car is a saab 93 1.9 tid 16 valve 150 bhp vector sport
    i have a long running problem with limp mode
    it happens when i accelerate hard from 3rd gear to 4th then slumps into limp mode if i turn the key of and on again its back to normal
    and sometimes happens first thing in the morning
    ive replaced the fuel filter and done a service also no change and replace fuel rail and sensor with matching part numbers
    ive connected opcom and get these codes p0001 75 which is low fuel pressure
    now i have replaced high pressure sensor and its worse and code for it is p0001 5b
    also have glow plug warning
    fuel pump in tank runs for 10 seconds on ignition being on.maybe its pickup is clogged?.
    ive had tech 2 scan on it before same codes minus the p0001 5b
    im at my wits end with this problem any ideas would be helpfull thanks
  2. Remove Advertisements
  3. #2
    Re: 2008 saab 93 tid limp problems
    Hello is it a 120 or a 150 BHP ?
    Because on your introduction post you put that you have a 120 BHP
    good way to find out if in doubt is what side is the oil filler cap ( looking from the front )
    If it's on the left then it's a 120
    if its on the right its a 150
  4. #3
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    yeh ill change that now its 150 bhp
  5. #4
    Try this download for wis ( workshop information system
    https://www.google.com/amp/s/www.saa...t=622081&amp=1
    Sent from my TA-1024 using Tapatalk
  6. #5
    Quote Originally Posted by lizzard-t View Post
    Try this download for wis ( workshop information systems
    https://www.saabcentral.com/forums/s...d.php?t=622081
  7. #6
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    thanks for that ill try figure something out with my readings
  8. #7
  9. #8
    From what I can see it seems that the saturation levels on the DPF are way high it should read about 70% +/- before regeneration. Then drop to 25 +/- after
    But I may be wrong .
  10. #9
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    theres no dpf on it pal
  11. #10
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Peterborough,Cambs,UK
    Posts
    1,099
    Looks like the DPF has been mapped out as temp sensors and DPF values make no sense at all.
    Whats the history on the car did you get the car mapped?
    The fuel issue could be bad map related or the high pressure fuel pump not coping........looks like a fuel demand problem.
    Your injectors are spot on.
    You also have no readbacks for the rail pressure solenoid for whatever reason?
    https://www.youtube.com/watch?v=wD6BNZV6QBE
    I recall there were some changes to the fuel sensors ...they went to one on the fuel rail at some point?
  12. #11
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    thanks for reply theres no dpf visual.yeh the sensor not having any reading is weird.i plugged each sensor out individually and wouldnt start with them out so does that mean they work?.i got the car mapped but the limp mode was happening before this.its just worse now when i accelerate hard between 3rd and 4th gear she goes into limp and sometimes in the morning.definetly fuel shortage but where i dont know
  13. #12
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Posts
    1,099
    Troubleshooting steps for the fault code P0001 75
    This relates to the high pressure fuel pump driven by the cambelt.
    https://i.imgur.com/eZkOkD2.jpg
    https://i.imgur.com/DvDcsXS.jpg
    https://i.imgur.com/uofRn2d.jpg
    https://i.imgur.com/jQTsthM.jpg
    https://i.imgur.com/WceUshd.jpg
  14. #13
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    cheers for that pal hopefully i can figure this out.not great with a multimeter when picking right options on the dial for each test
  15. #14
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    ok so i did a bit of testing
    fuel rail pressure senso readings ignition on
    pin 3 got 5.0 volts
    pin 2 got 5.0 volts
    pin 3 got 0 volts
    wiggled all the wires aswell
    see pics
    high pressure sensor plug got
    12 volts ignition on pin 1
    pin 2 with ignition off got 123-128 ohms
    can someone take a look and see if you have any ideas thanks alot
    https://mega.nz/#!WAhDUSTB!HvTVNl54-...dH907EPxNW95PY
    https://mega.nz/#!6UgHVIxI!75WWSrs1U...iyNnXKUKdsDAEw
    https://mega.nz/#!qIwFmaAA!Wy8-HbQOq...JmBOq29lhmrPZQ
  16. #15
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    sorry for late reply weather was terrible couldnt get to testing it
  17. Remove Advertisements
  1. 93 tid Eml and limp mode. Code P1625
    By Bullring in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 05-03-2014, 06:07 AM
  2. 3.0 TiD Intermittent Limp Home & Other Problems
    By [email protected] in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 12-11-2009, 05:52 AM
  3. 93 Sportwagon 150 TiD in 'Limp-Home' mode
    By biggles1 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 08-18-2009, 06:54 AM
  4. Safe or "limp home" mode ECU throttle control problems
    By wpnason in forum Saab 9000 (1984 - 1998)
    Last Post: 11-02-2004, 06:32 PM
  5. Safe or "limp home" mode ECU throttle control problems
