2008 saab 93 tid limp problems - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: 2008 saab 93 tid limp problems
  1. #16
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Peterborough,Cambs,UK
    Posts
    1,115
    Re: 2008 saab 93 tid limp problems
    According to the WIS you should have more than 500Kohms between Pin2 and ground at the high pressure fuel pump.
    You could have an ECU problem
    https://i.imgur.com/oP2kdA5.jpg
  2. Remove Advertisements
  3. #17
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    havnt checked edc module could it be the wire from pin 49 to pin 2
  4. #18
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Posts
    1,115
    Quote Originally Posted by voodooirl View Post
    Yes you could tap a wire directly from 49 to 2 to eliminate but the fact you have a low resistance means it isnt broken.......... suspect there is a control resistor in the ECU somewhere that may be bad.
  5. #19
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    if i check the resistance from pin 49 directly that should tell me what i need
  6. #20
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    havnt touched the ecu yet.but disconnected the battery and now the fuel gauge doesnt work and getting please refuel msg aswell any pointers thanks
    this is fixed
  7. #21
    Saab Newbie
    Join Date
    Jan 2019
    Location
    dublin ireland
    Posts
    14
    just checked pin 49 direct from ecu only getting 90 ohms. looks like the ecu is at fault
  8. #22
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Posts
    1,115
    Best route is probably to get the ECU cloned to another or hunt for a used ECU on Ebay of the same part number and pair to the car with Tech2.
    I know someone who can do the cloning although you would have to remove it and send it across to the UK.
    The ECU needs to be opened and relevant memory chips(immobiliser and map) probed then transferred to a donor using something like Kess.
    if you want details send a PM.
  9. Remove Advertisements
  1. 93 tid Eml and limp mode. Code P1625
    By Bullring in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 05-03-2014, 06:07 AM
  2. 3.0 TiD Intermittent Limp Home & Other Problems
    By [email protected] in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 12-11-2009, 05:52 AM
  3. 93 Sportwagon 150 TiD in 'Limp-Home' mode
    By biggles1 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 08-18-2009, 06:54 AM
  4. Safe or "limp home" mode ECU throttle control problems
    By wpnason in forum Saab 9000 (1984 - 1998)
    Last Post: 11-02-2004, 06:32 PM
  5. Safe or "limp home" mode ECU throttle control problems
